Help needed plz - Cartier Ballon Bleu
startupnow
2/8/20
Hello all,
I am about to buy Cartier ballon bleu 42mm SS bracelet with black dial. But, I am confused between the AF and V6F factory.
I haven't seen both in reality, but I noticed from pic/video that the AF has better dial detail and clear crystal blue stone on the wheel time adjustment, and the thickness is close to the Gen. On the other hand, people still say V6F is the best, which make more confused!
So, from your experience which one has better quality, looks/feel, movement, thickness, blue stone,,,,, etc.
Your advice is highly appreciated. Thanks in advance,,
Sent from my SM-G986B using Tapatalk
Jandirrty
1,190
59
Overall v6f is better. AF has better case and bracelet.
startupnow
2/8/20
Thank you very much for the reply. Any idea how the AF scores low against the v6f?
I heard that the AF thickness and movement are sort of improved!!
Jandirrty
1,190
59
I have sold more than 5 Cartier on rwi both V6F and AF. Overall AF has a better detailed finish and pink dial 33mm is best with AF. If you are going with white 42mm go with v6f only.
Reactions: SuperBatman
startupnow
2/8/20
Great insights!! thank you very much my friend.
xcarrerassanchez
37
I have sold more than 5 Cartier on rwi both V6F and AF. Overall AF has a better-detailed finish and pink dial 33mm is best with AF. If you are going with white 42mm go with v6f only.
What about the 33mm quartz versions? Also between AF & V6F cannot decide...
xcarrerassanchez
37
xcarrerassanchez overall detailed finish AF. But v6f is as good and you save alot of money.
Thanks for the quick response! Since we are talking about quartz movements, the difference is not that big, it is 70 EUR. If the AF is a better rep, I will simply go for that one since I want the best quality possible (understanding that it is not gen).
Thanks anyway for your help :)
Pater_Pen
146
On the consensual super rep list, however, the V6F version of the Ballon Blue is listes as potential super rep.
How does the AF version of the link compete? The price is intruiging
