HELP: Navitimer bracelet buckle
itseme
146
Hi
I've just received the navitimer two tone and i have a problem. There is something missing so that the buckle wont hold the band together (sorry for my bad English) i don't know if a screw is missing or how this is normally hold together. The dealer told me he will resend me a buckle, but can switch the buckle easy??
Here a picture. The arrow shows where a screw or whatever is missing:
Natron
1,419
I have some spare buckle pieces so if you need them let me know,
Natron
Importr
1,799
447
a good watch repairer can fit a new stainless steel pin to that...
andreww
2,249
That really doesn't look right. It almost looks like the clasp piece is from one of the wider 24mm bands, The width of the clasp should be equal to the width of the bracelet, and the deployant extension. Yours seems to be an extra few mm wider.
itseme
146
@andreww
This is only on the pic, it has the same witdh, but how is the clasp fixed with the pin? Because i dont see a screw or something...
Greets
andreww
2,249
Mine is a permanent pin. It can't be removed. Both ends flare out over the hole if you know what I mean.
