Help! My CG lost it's snap!
faberjay111
2,738
Hi Pam experts,
I have a problem and need help!
I have a beautiful franken 170 that I absolutely love and wear quite often. The cg has the wonderful "snap" that it's supposed to have. Yesterday, I was wearing it. It had the "snap"....then, 10 minutes later...no more "snap"!
At first I thought that the cg screws loosened. When I got home, I immediately took the cg off and put it back carefully. I made sure that the cg screws were tight.
Still no snap....ARGHHH!!!
Does any know what could have possibly gone wrong?
Thanks in advance guys....
NCchef
806
Gaskets flatten over time. Also the rubber gasket in the lever pin hole can get weak. Both are causes of losing resistance
Bozz
2,748
+1
add an o-ring to your crown, internal Ø 2mm
