Help: modifying a Rolex dial
nbeezy
98
67
Hello RWI members,
i contemplate modifying/replacing the dial of a sub no date.
The objective would be to somehow get rid of/cover the Rolex branding on the dial. (maybe replacing the dial is an option too?)
I would highly appreciate some insights on what is the best approach to persue here. It wouldnt necessarily have to be a DIY soultion.
Thanks a lot!:)
WatchSmith.US
1,307
2,060
Wiping the lettering with alcohol can remove it, but results are usually not good. It can leave ghost outlines and worse. I would never attempt this on a dial that has value.
nbeezy
98
67
Thanks for your input!
We are talking about a rep watch ofcourse. Is there a relatively easy way to swap a non rolex dial into a watch like this (40mm no date)?
Or am i better off trying to modify the current dial?
raspan1123
240
213
you’re honestly probably better off looking for a dial without the prints on aliexpress
nbeezy
98
67
As far as i know the movement in my watch is a replica of the 3130 Rolex kaliber. So i dont really know what specs need to be met for the dial to fit. I couldnt immediately find dials that are advertised to fit a 3130.
Natas78
Trusted Watchmaker
Vendor (Watch Repair)
4,146
2,401
If you have kids then most likely they have really tiny stickers that you could put over it if you don't care about brands but don't mind thinking of your offspring every time you check the time.
nbeezy
98
67
So i would have to get kids for that to work. Might be out of my budget im afraid.
