As you all know the 202a from DSN comes with a nipple on the cg aka the cg pin. I would like to file it down. Then I'm going to heat the pin and drop it in flax oil to make it black and repeat until I have the desired color.
My question is I found this pic:
http://www.watches24seven.com/gallery2/main.php?g2_view=core.ShowItem&g2_itemId=9164
From the pic it doesnt even look flush...like I'm better off keeping the nipple...what do you think?
Would you polish the pin like a normal SS crown and then blacken it or file it down and then make it black? So either a flat black or a semi-polished black...any help would be awesome
Thanks in advance
Thanks in advance
