Help me decide: BCE with Diamond bezel: Which dial?
cy0811
All Graphite dial or Black dial with Silver subdials?
Which will look better with the Diamond bezel?
Most gen are black or white with bling it seems.
Thanks
Cy
hk45ca
11,843
the darker the dial the more the diamonds will show up. that is one of the reasons i got the white dial. how much do you want it to show? if you can get a grey/graphite dial with the correct inner bezel color and color of the word automatic i would get it.
Rxus
56
If your getting the diamond "bling" bezel...why not show it off?
Get the black dial with silver subs let that baby shine 8)
hk45ca
11,843
i always say if you are going to roll you might as well roll high and hard!!!
cy0811
Tough choice...I do like the white which is discontinued but have narrowed it down to the Black or Graphite. Im beggining to think the black may look a little better with the diamonds since the silver subdials will add to the effect. I do however think thr graphite dial may look good as well. ????
cy0811
Here is a pic of a typical version 1 ultimate graphite dial.....Im thinking the black with silver subdials will look better with Bling then the slightly duller color of the graphite. Opinions apreciated.
jimb
22
Any dial choice would be good . but stay with SS case the diamond blends better with SS.
hk45ca
11,843
the graphite dial is wonderful but i also think the black with silver sub dials will add to the effect. 8)
cy0811
But in this pic the graphite looks like it could be awesome with the diamonds.?????????????????
dave123
1,313
who's watch is that with the 45 where the 15 should be and vice versa?... :)
question for you guys,every BCE with diamond bez. gen i have seen has diamond markers....does a non diamond marker gen with diamond bez. exist like the reps?...
hk45ca
11,843
yes, the diamond markers i have seen are always on a mop dial.
chillininla
112
I think the graphite dial with diamonds will look blinged out yet still classy, the other one may be a little over the top. (just my opinion)
cy0811
Edit...the newest Graphite dial is very close and now I may go with that.
dlanzer
54
cy0811 ..... Did you pick one out? I know it is hard to choose ....
