Hello,
I wear my watches on my right & I'd like to put together something that looks like a PAM115.
For the dial I would get the upcoming Noob PAM 026, but for the case
can I start with a 111N and flip the CG so the lever points up? What would be the benefits of using a 219 case?...I see that the CG
won't be polished. I would also turn the 026 into either a PVD base or 111...will it be like legos? or is there a best combination to choose?
Thank you,
Thank you,
