Ok i have never done it before but it shouldn’t be so hard to bend it a little right ????
Gesendet von iPhone mit RWI
you can adjust them with a tool
A very very fine bending of the bottom bar of the clasp or straightening of the top bar will loosen it
like if you straighten the top bar it would make it longer and thus take the hook further away from the latch
you can see a tutorial on you tube
but its a fine fine adjustment, dont try it yourself if you dont know what you are doing
Just apply light pressure, holding the curved side towards you, apply a little pressure with your thumbs to very lightly straighten the curve - check if it's worked or not, if not apply a little more pressure the next time.
