- 4/6/15
- 181
- 36
- 28
Hi guys,
After being a silent reader for a while, I decided to create my first post.
As the title said, I need your expert help in identifying this 3135 movement. I picked this Noob V10 from a local marketplace, seller said it's running a 3135.
Upon opening the CB to grease the gaskets, sure enough, I found 3135 inside it. But I got a shock when I saw that it has blue hairspring (Like a VR3135).
I tried searching high and low for Noob V10 with VR3135 movement but I did not find a lot of info. However, I found that Noob recently came out with new movement to replace the old SA3135, also
known as NB3135. Not much information available as well.
So, does this movement similar to VR3135? i.e reliable and serviceable. Or unreliable and unserviceable like the old SA3135?
Cheers guys!
Cheers guys!
