Help identify parts for 126610
Dxp200
It takes a lot of balls to golf the way I do.
1,056
2,566
CONUS, FL
So I’m looking to finish the case on the right. Although the case is stamped as a 126610 it measures out to a 40mm, so it’s more like a 116610. I’ve compared it to my noob 116610 and the size lines up. The problem is that the components for the bezel aren’t the same. I need help identifying all I would need for the bezel. I think that a 40mm bezel will fit just right but the click springs aren’t the same and the crystal is loose so I’m sure it needs a retaining ring but I feel that sense the case is different the same kind of ring in my noob case might not work. This is where I’m stuck boys need the RWI army to help my figure what I need here
tripdog
Super Moderator
25,232
24,302
You'll need a retaining ring on that gasket. An 116610 bezel assembly may work, but you won't find out unless you take some measurements with a digital slide gauge/try to fit an 116610 bezel assembly.
Dxp200
1,056
2,566
CONUS, FL
Thank you sir, I ended up pulling off the one on my noob 116610 and it all worked with the exception that I mangled the bezel gasket and couldn’t get it on. I ordered a new one, first time working on a 116610 bezel. It’s a bit more than the 5 digits I’m used too.
Reactions: tripdog
