Help identify KW PAM441
jumphigh
27/5/14
Just got this KW PAM441, the AR seems unacceptable to me, the crystal reflects everything and makes it hard to check the time. Just wondering if someone can identify which version of PAM441 this is, and is this the best version out there?
capnjazz
166
45
Judging by the balance wheel at 11 o'clock its the A7750 PAM441. I just got the same one recently, though yours might be an earlier one as the word "CERAMIC" on the back says "OERAMIC". I saw one like this previously posted on here, but the one I received last month had the correct spelling on the back. Other than that, yes, this is currently the best one out there as far as I know.
ALE7575
Section Mod
19,846
423
This rep seems a ceramic KW PAM 441 fitted with a P.9000 decorated A7750 with NON-inverted layout KP9000-V2
But I don't understand OERAMIC inscription on the back, because the wrong inscription caseback at the beginning was CERAIMC not OERAMIC
Really weird. I never saw that. But the movement is KP9000-V2 and the rep is ceramic seeing the CG.
ALE
Norrie
2,063
64
Sorry mate but this one is made just like the gen which also has the same AR, or lack there of.
electick
114
gen has same light reflection, same AR. anyway crystal is slight dome shape so its ok to have some reflection.
humsup77
10/3/15
Hi,
Which version of PAM441 is this ? V6F ? i see the case back very strange.
Look at the "xxx CERAMIC" and "Titanium Case Back" in one block, where others i see "LUMINOR 1950 CERAMIC" ..
which factory or version is this from?
ALE7575
Section Mod
19,846
423
It is a KW-V6Fac PAM 441 fitted with decorated Seagull NON-inverted
The caseback is from a PAM 438, as commented by Sora
ALE
