[HELP] GEN Dial Swap on ZF 67650 – Date Window Alignment Problem
Criptix
17
20
Slovenia
Hello! I recently purchased a ZF 67650 with a Swiss V8 ETA quartz movement. To complement it, I also bought a genuine dial from the 67611ST. Excited to perform the dial swap, I realized that the date window on the GEN dial is positioned further to the right compared to the replica dial. Also, when I Google the 67611ST, I found that the same reference number doesn’t necessarily mean the date window position is identical across all models.
What are my options here? Should I try to find a GEN quartz AP movement and swap it in? Or are there other movements compatible with the ZF case and GEN dial?
Thanks in advance for all your responses! Cheers!
OffshoreNL
809
503
A gen movement is gonna cost an arm and a leg. Some pictures would help
OffshoreNL
809
503
With my limited franken/genstein knowledge it looks like there is no other way than a gen movement. Maybe @legend can give his 2 cents and save you from going down that route.
