Help fixing loose minute hand?
yo!
42
I've never tried this and I am new to rep watches. I've got a 2836-2 movement in my Rolex Yachtmaster and just the minute hand is loose.
I can set the hour hand, the second hand ticks away fine.
Tutorials? I'd like to learn a little something? I might need some tools but that's fine.
Fiddo
9,051
6,180
In a Causal Loop
By loose, do you mean floating around inside the case?
If so, this tutorial-------------->
http://forum.replica-watch.info/vb/showthread.php/how-service-your-movement-tutorial-11086
shows you the steps you will need to follow to remove the movement and dial from the case....which you will need to do in order to re-seat the hands. The tutorial also outlines the complete service of the movement.....which you should not need to do. :)
If you follow the steps, it's not too difficult.
yo!
42
Just the minute hand is loose and it's NOT floating around in the case. It's just loose from the center mount [what ever it's called], LOL!
katt
Trusted (Watch Repair)
Trusted Dealer
Vendor (Watch Repair)
14/9/09
1,043
If its not loose or detached from the Cannon pinion then it may be that the C.P. itself needs tightening .
