help deciding which 386!!!
menos
78
Hi all, i ve been searching for 386 and now stuck on whether to choose the KW or ZF.
Apparently KW has the CAL 9000 upside down, whereas the ZF has it correctly.
I have searched through forums, read the pam guide etc but stil having a hard time deciding on which one to go with.
Are there any other differences apart from the CAL9000 being printed differently?
mysterio
9,793
867
As the gen apparently has been cancelled by Panerai, I don't think accuracy would be your primary worry. The latest is from KW (V4) so I would recommend just based on that fact.
PolonusTM
2,165
809
Both versions are A7750 based - thus both have CAL 9000 upside down... By some kind of "tradition" we expect Kuvarsit's version to be better executed.
menos
78
Latest from kw was v5 when i checked.... v4 ss dlc and v5 titan dlc
menos
78
The engraving of cal9000 is different...... i will link the rotor when i m fre
PolonusTM
2,165
809
So it was about rotor's engravings not the whole Caliber 9000 rep movement... ;) Misunderstanding on my side.
mysterio
9,793
867
I see kuvarsit did not update their website and I am not particularly interested in this rep so I don't follow the versions.
ALE7575
Section Mod
19,847
438
IMO KW V5 Ti DLC coated version is superior in finish and movement ("real" jewels instead of painted ones)
CAL P.9000 inscription is not worse it is just a different approach to the gen
Since movement A7750 has inverted layout the inscriptions cannot be the same as gen
In Gen CAL P.9000 is placed inwards and inscription finished with P.9000 near the balance wheel.
With an inverted layout you cannot get two above mentioned conditions. In this way, if you have inscription placed inwards the inscription will start with CAL close to the balance wheel (inaccurate). If you want the inscription finishes with P.9000 close to balance wheel you will need to place the inscription outwards. You cannot keep both conditions
ZFac has just adopted first solution with inaccurate CAL close to the balance wheel
KW has just adopted second soluion with inaccurate placement outwards
Both have some kind of inaccuracy
You will get, besides, more consistent quality in KW version
In PAM GUIDE is everything commented and even better eveluated KW V5 version
But always a rep has flaws and you should choose the rep flaws you can live with
ALE
bassmanz
89
KW V5 ++. Case is great and is standing up to wear.
kayabun
291
Buy it :) Great for work. Not too showy for work.
menos
78
So much love for KW :O
Now i just need to get my wifes permission
Matjalee
41
Jeroen, you can buy directly frm Kuvarsit. They have excellent services
Sent from my Lenovo S820_ROW using Tapatalk
svshawn
527
160
Got mine from puretime. ZF and love it!
QC pic as my pix don't do this piece justice.
