The retaining ring is just like any other 16610 ring - you need to get a thin flat blade under it and work round it, prising it up. It’s tight and probably very well seated, so you might have to start off tapping a razor blade in between the case and ring.
The bezel is fun to reassemble - if you disassembled it correctly then it should be quite easy to understand the principle, but maybe you managed to force it off without removing the wire circlip first? (Although I’ve never managed to do that - I have bent two bezels while trying though). Anyway, to reassemble I find the best thing to do is bend the long click spring into position inside the bezel, and then place the spring/bezel assembly in position, relocating the end of the click spring in its hole. Then, the bezel is secured in place by feeding/bending/clipping the circlip back into its location in its grooves under the retaining ring and in the bezel.
There’s probably a pictorial guide on here somewhere… because a picture paints a thousand words and my rambling explanation may not have helped much… I had a quick search but couldn’t find one. But I know I posted some pics myself somewhere, when I bent my BP bluesie bezel.
Good luck!
The OP's has the wire circlip KJ - it's just that they managed to force off the bezel without removing it - it's poking out from the bezel if you squint carefully.Also the BP Sub bezels use an 8 sided wire clip to contain it under the case lip.
Also, I'm pretty sure there's no removable crystal retaining ring on the OP's case. I always forget all the details of the BP's peculiarities compared to gen spec, but now you mention that, I'm even more inclined to think this is a BP. It may however have had its hands changed, because as you point out - the lume on the hands is yellower than the dial.
OK see it now bro. I had some doubts about the dial too after doing a close compare - BP Sub dials have a short ft and space m. His m looks different albeit mostly hidden and pretty blurry.
Very interested in the serial and clasp code. But yeah on BP 5 digit Subs or GMTs you can change the crystal without taking the bezel off. I never do anymore precisely because of the hassle involved. The movement comes out, push the crystal out from inside, remove the insert, replace gasket and press new crystal, replace insert.
That does not look like any BPs I've had. The retaining ring on every one I've had in hand is not removable - it is molded into the case. So you can just push the crystal out from the inside as is. The crystal gaskets are shorter in height than gen-spec so you just refit the crystal gasket into the space inside the "retaining ring" and press the crystal down into the gasket from above.
The BP DG and ETA crystals are not gen-spec, having a 30.4 mm OD with a straight edge profile so they are one diameter on edge. The BP 3135 crystals are gen-spec, having a stair-step edge profile with a 29.5mm lower diameter where they connect to the gasket. But whatever the crystal used, the same "retaining ring" arrangement and a short height gasket is utilized.
Also the BP Sub bezels use an 8 sided wire clip to contain it under the case lip. The hands and dial lume on this one don't match and the hands don't look like BP hands. So again this does not look like a BP to me.
What is the origin of this piece, the clasp code and serial number?
So, if I wanted to replace an insert on a BP 16610, I should remove the movement (and dial and hands attached) and just push the crystal out with my thumbs? This would give me access to the rear of the insert to remove it? Then just push the crystal back in?That does not look like any BPs I've had. The retaining ring on every one I've had in hand is not removable - it is molded into the case. So you can just push the crystal out from the inside as is. The crystal gaskets are shorter in height than gen-spec so you just refit the crystal gasket into the space inside the "retaining ring" and press the crystal down into the gasket from above.
You'll have to make one bro.Curious if anyone knows a source for the BP crystal gasket. I can’t find one!
Yes, exactly that. If the crystal doesn't come out easily by hand a press will certainly do it.So, if I wanted to replace an insert on a BP 16610, I should remove the movement (and dial and hands attached) and just push the crystal out with my thumbs? This would give me access to the rear of the insert to remove it? Then just push the crystal back in?
When you bent the bezel how did you rectify? Purchase a new bezel and if so do you have a source? Did you straighten it?The retaining ring is just like any other 16610 ring - you need to get a thin flat blade under it and work round it, prising it up. It’s tight and probably very well seated, so you might have to start off tapping a razor blade in between the case and ring.
Good luck!
