Help authenticating this 2836
panac
943
161
Hi guys I just picked this up today for my seadweller and need your eyes on identifying if this is a real Swiss 2836.
Thanks in advance
rsh
5,137
looks swiss
BTW that notch in the movement ring needs to be by the hole to release the stem
Corral
127
I presume you paid for an A3135 and found this when opening the case? It does look like an ETA 2836-2.
Sent from my GT-I9300 using Tapatalk 4
panac
943
161
No I got it as a Swiss 2836 from a member I just bought the movement though, but it came housed in that case. I know the hole doesn't line up. To me it doesn't look Swiss cause of the eta stamp isn't centered but I'm could be wrong that's why I needed your help. Ether way it's going in my sea dweller
Corral
127
I see. Hopefully someone will enlighten us soon.
Rollex
987
How about another Angle, and we bump up the Rez ;)
Corral
127
From what I've seen on the bloc it is curved and compatible with the ETA bloc.
panac
943
161
Ok thank you guys as always you have eyes of an eagle
panac
943
161
@ssteel how can you tell that the keyless is screwed
Ko67
1,223
118
Looks like a Swiss ETA with the keyless screwed.
Looks Swiss to me also. Micky is right that the Keyless works are jacked up because the stem release pin on the setting lever part 443/1 does not shown in the hole/slot where it should .
