So, I want to replace the He-valve. It's not drilled through - there is no screw or anything else on the other side. It's just smooth surface. It would seem it's glued on (or stuck on the case by some other means). I can't move it in any direction. Granted, it's water proofed for sure, but I'd still like to stick my gen on there. I was planning on being able to "use" it (ie being able to screw it) but I'm thinking I'll just chop the gen valve in half and epoxy it. I probably have to drill the old one away, without hurting the case.
Has anyone who did a He-valve swap seen this before? I'd like to get some input before I start drilling away on the He-valve. Maybe there's a much easier way?
