Green sunburst Destro 4-liner
Belkin12
Supporting Vendor
26/10/12
340
1,250
Ukraine
Hello gents.
Here's the recent build which is quite unique due to the not so common emerald dial color.
- 44mm old cartel SS case, reshaped, softened edges. Mirror polished. Improved water-resistance.
- Heavily modified destro CG with custom made flush pin. Heavily modified lever - the tip is thinned and is closer to the midcase compared to a stock lever. Lever moves smoothly, not flimsy.
- Thinned crown with deepened dish.
- Thick single-dome crystal. No AR coating.
- Display engraved CB.
- Completely serviced (washed, oiled, re-assembled, regulated) a6497 movement. Engravings on bridges. The Train bridge wheels are radial brushed.
- H3 CP/HW.
- Flattened and polished cannon pinion.
- Movement holders made to firmly secure the movement in the case.
- Custom made dark green sandwich LPMM destro dial. Sunburst pattern. Flat and smooth ultraglossy finish.
- Custom made 0.3mm brass backplate. Soldered dial feet for 6497 movement.
- Custom brass hands.
- Off-white lume with green afterglow.
- Titanium lug tubes.
- Custom brown leather strap with whitish stitch. Size is 110mm x 70mm.
- 22mm screw-in buckle. Engraved and mirror polished.
lesuedois
39
47
Extraordinary as usual with Belkins output. Gotta love the destros too, there's just something magic that happens with the overall balance on those.
