Greasing and movement???
Hakai
257
98
1. Hey just greased the inner gasket and outer gasket of the stem. Also greased the crown from the outside and inside.
So while always screwing it out, there will be some dirt on it. Is it neccesary to clean the crown and grease it again everytime it gets dirty ?
2. I want to remove the movement 2824 to seal the HEV on my SesDweller. I read up some tuts on how to do so. There are two screews holding the movement inside the watch, by fixing them to two small metal stakes. If i remove the screws, how can i remove the stakes? Or can i just turn the watch around and the movement will fall out?
Thanks in advance
