Going grazy
Zkebam
240
I am going grazy here. Just put on my watch en saw I lost something yesterday, sorry I don't know the English word for it but I took a picture!
What can I do??????????!!!!!!!!!!!!!!
trailboss99
Head Honcho - Cat Herder
Administrator
43,646
17,455
Buying a new crown guard would be a good start.
This is why you mush check all screws for tightness when you get a new watch.
Zkebam
240
Believe it or not, I checked the screws!!....probably not good enough :-(
CP2K
453
That's too bad! I feel really sorry for you, but you will still be able to repair it properly.
ALE7575
Section Mod
19,846
423
What model and version is this?
So that we can be more careful...
This is a rep general issue not focused in some models or brands.
But is very famous in H screw bezel of Hublots and in PAM lug screw and CG screws.
You must tightening screws and to apply some appropriate Loctite.
ALE
Zkebam
240
It's the 243M Noob V2
And yes Ale, I agree.....but on the other hand I expect that screws are tight, but maybe I expect to much?
I will order a new Crown guard.....can you tell me what kind of Loctite I need, I'm not sure I can buy it here in the Netherlands.
Thank's, Wim
ALE7575
Section Mod
19,846
423
Thank's, Wim
YES, you are expecting TO MUCH in replica world.
Usually many screws are not tightened.
The best Loctite for this purpose is Loctite 222 or 222ms
http://www.tessco.com/products/displayProductInfo.do?sku=483698&eventPage=1
If you don't find it, is enough a Loctite threadlocker midium resistance to allow manualy disassembling. Loctite 243
http://comparar.ebay.es/like/220749331922?ltyp=AllFixedPriceItemTypes
ALE
Rick914
2,016
Texas
And be sure to use the correct screwdriver so you get the correct torque on the screw without messing the screw heads up, a very common mistake.
Zkebam
240
Thanks Ale, you are very helpful. I found 222 here!
What a great forum this is!!!!!!
ALE7575
Section Mod
19,846
423
THIS IS AS IMPORTANT AS THE LOCTITE
Thanks
ALE
iggypop
2,297
I'm scared now.
has this losing of crown guard happened to anyone else?
Zkebam
240
Just got the 222. What is the best way to apply.....can you tell me Ale.....or anyone?
Thanks!
Rick914
2,016
Texas
Use a tiny drop on the threads only. Torque as normal. Let set up before getting wet. Don't try to break loose once it's dry unless you are removing the screw. Clean and reapply each time.
With loctite, more is not always better and a little goes a long way.
Zkebam
240
Thank you Rick.....my english is far from perfect!....so can you tell me what you mean with " Let set up before getting wet" ?
Thanks!
Rick914
2,016
Texas
Let it properly dry before swimming, shower, and other water activities.
Let it dry for about 24 hours to be safe ;)
