From Start to finish
TWP
2,429
Dear All
Use this as a reference or a tutorial. My wife is out of town and the boys are sleeping so i have a little bit of free time. On the agenda the complete process of modding a panerai. The speciman a new asian h series swan neck movement.
Before Shots
Where is the freakin lume. You will see shortly an unlumed dial and that might give you guys some ideas
The most important thing is to have proper instruments. Personally, i use about seven; forceps, two screwdrivers, cannon pinion pull and crimper, caseback remover, and hand setter.
Below the most important. Angus sells these on a regular basis. If you do not want to use a caseback remover than you can buy a sticky ball from ofrei or use some duct tape.
Everyone does this differently, and I guess mine is just habit. Once the caseback is removed and remove the crown guard
Once the crown guard is removed the movement should look like this. Notice the two movement holders. I remove both of these and then proceed to the crown. The crown is captured by a tiny screw that you must turn counterclockwise about one and 1/2 turns. Be very careful not to turn the screw to much as this will result in messing up the keyless works on the lever. Just 1 1/2 turn.
Once the crown is removed I lay the dial out on a piece of paper, or movement holder . I also take the o-ring out of the case and the crown and put in oil
You can see the recessed cannon pinion
Using a cannon pinion and hand tool I remove all three hands. Be very gently when you remove the hands as you do not want to damage the dial. Notice the nice finish on the asian movement
After seperating the dials with a #11 surgical blade this is what you have. On the left the unlumed dial, and on the right the C9/C3/C1 mixture of superluminova
Now it is time to remove the insufficient cannon pinion. Notice that the keyless module has been taken apart. This is crucial when pulling and reinserting the new eta H3 cannon pinion. Be very careful not to loose the spring . If you do this then the crown lever will not work
The new cannon pinion installed and the keyless reassembled. When pushing on the new cannon pinion you should hear a click when it is seated
The next step may seem simple but this is another crucial part of the process. When putting the two plates back together the holes must line up perfect. Below pay close attention to the running seconds stem. You will notice that it is not centered in the hole of the plate. I did this to illustrate. In this position you will find it impossible to properly put the seconds hand on securely. Also you will run the risk of damaging the dial
After installing the hands and checking the movement, work your way backwords. Here is the finished product on a strap culture limited edition croc stap
My favorite part is the lume :)
crunch
79
Very informative tutorial you have illustrated~~ You make it seem so easy.....your tutorial + H_U's CG mod can make one hell of a modded piece~!!!
Million thanks!!!! :mrgreen:
sharpie12070
188
15
TWP, those are such wonderful shots; sharp and clear. couldn't be better. one of these days, i always say, i'll open up my pams and do something to it, anything :D
TWP
2,429
Thanks guys. Yeah now the crown guard is different tutorial on its own :D
I may share that one tomorrow night :D
Sin22
5/10/07
Do you remove the previous lume from the hands or paint over them?
If you do remove them, is it just a matter of sanding/scrapping/cutting it out?
Thanks for the info and great tutorial
MEYER8888
965
very good job, thanks for this good rewiew.
and nice combo watch too!!!
opak
57
Damn nice of you to do this. Very interesting read! Thankssss :wink:
TWP
2,429
Hello
The old lume is taken off with stripper, one dip to be exact. It is sold at ofrei. You will run into several problems when you relume over existing lume. Most important, the height of your lume in relationship to vital structures of the watch. If you go to heigh then you will never be able to get the seconds hand back on properly, if at all. Second, the desired color will not be achieved as the older lume will show through.
Hope that helps
Cheers
t
therebel
767
Awesome tutorial TWP. Too bad I'm too much of a butter fingers to do this myself. I've destroyed too many watches to count. Hence me ordering millions of them from you :D
MK08
836
That was a great read! Thanks TWP for your step by step walk through with excellent pics, makes me want to get myself a beater Pam and give it a go :D
