Franken Patek 5712 Project
jptrosch
413
405
I wanted to share with you guys a project I've been working on for a while now. Last October I grabbed a badly damaged Caliber 240 with a grey dial from a Patek 5712 off eBay - missing screws, jewels, rotor, damaged balance wheel, bent stems, etc. I sent it off to a watchmaker in March to start repairs, and based on a a call I had with him this morning they're almost done.
So far I've sourced a set of gen hands (including the small hands), gen caseback crystal, gen gaskets, and aftermarket end-links.
The next phase of the project involves getting a PF bezel and midcase, thinning it, making a new caseback, and somehow figuring out how to add pushers. If anyone has any advice, please feel free to chime in. I've included some of the movement photos from the original ebay listing below.
Hunvaakaren
288
34
Wow, this is going to be a insane project.
May i ask how much the movement went for? Aucthion?
And what is your budget to this project? Good luck, I will follow up on this one.
majwilliams0308
Reptime Mod
2,442
2,405
I would think - Buy the KMF with pushers in it (link here: https://www.intime05.co/patek-phili...ck-dial-on-ss-bracelet-calendar-movement.html)
Then have your modder drill a hole in the PF case and transplant one of the KMF pushers into the PF case. It should fit that way, but it's almost a waste of a $368 watch just for a pusher haha. But I don't know what other options are available (i.e. how much gen pushers are, or if third party pushers will work).
SuperLory
Well-Known Repist
22/10/15
8,515
5,124
an acquaintance has the gen and it's a stunner
Wish you the best and will definitely follow this
Reactions: jptrosch
d4v3
DO NOT TRADE WITH ME
912
266
Cousins sell them as correctors, size check its needed to choose them, normally you have to stick a custon end inside to adapt to your movement.
Reactions: jptrosch
jptrosch
413
405
A note to everyone who's been messaging me about buying the project, I'm not selling it. The repeated insinuation that I would grow bored of it and that you would be willing to take it off my hands because you could handle it is disrespectful. I intend to finish what I started and give the watch to my dad for his 60th.
jptrosch
413
405
I just looked them up. Thank you, that's a promising lead. I appreciate it. Echoing what majwilliams0308 said, it would be a shame to have to buy a whole watch just for the pushers.
A buddy of mine has the gen - I may be able to get the dimensions from him.
slaughterer62
27/1/13
9,280
1,892
Love how this project winds its way towards a kindred zone. Keep it going: best entertainment for me for a long time.
Reactions: jptrosch
jptrosch
413
405
So, any progress?
Not much to report. We've had to replace most of the gear train and the focus right now is straightening out the mainplate. The seller wasn't sure how the movement was damaged, but by the looks of it someone ran over the watch with a car. Luckily, the dial side is mostly unscathed. I'm holding off on the case until the movement is done so I can make sure it fits - actually just sold the ppf I was going to use because I couldn't live with the fat bezel and crown.
jptrosch
413
405
Update: The movement is officially running.
It's hard to tell from the photos, but the plates have been straightened out and the gear train and balance assembly have been replaced. There are still some missing parts and stripped screws that need to be made/fixed. I ended up buying a new dial, so we don't have to wait for that to be restored before putting the watch together. Overall, I'm feeling good about it, and I'll probably buy a PF 5711 and look into modifying it after CNY.
m1994
619
744
Wow this is amazing, congratulations!
What are the dimensions of the gen compared to the 5711?
jptrosch
413
405
The 5712 is .2mm thicker than the 5711, but I'm not sure where that extra thickness shows up. My plan is to get a 5711 case and then compare the crown against a profile shot online to create a scale I can use to measure the thickness of the bezel and caseback. Making the crystal hole on the caseback larger will be easy, but I need to find a way to get rid of the divets from the caseback opener.
