Franken BCE project
chillininla
112
Hey guys,
I'm workin on a franken BCE project.
I want to install a Swiss 7750 and Gen dial into my V3 BCE (updated date wheel)
I have all the parts, BUT I'm finding some conflicting info on whether the hands from the A7750 28k bph will be a direct fit onto the Swiss 7750 unsure.gif
Anyone done this mod or have any info on it?
Any help would be greatly appreciated.
guru
11,730
1,450
I have done this mod on my Avenger Black Steel and I will get my Super Avenger back this week from a movement swap. Should not be a problem at all.
What are your concerns?
chillininla
112
I'm mainly concerned about the hand stem size difference between the A7750(28.8k) and the Swiss 7750...
I've read that there is a diff in the seconds and subdial hands, or is this not a real problem?
BTW who are u having work on your watches if you don't mind me asking, I'm still looking for someone to do the work (PM if necessary)
takashi
11,500
The trickiest part to fit is chrono second hand counter. Apart from that, should not have big worry.
guru
11,730
1,450
Specification of ETA 7750
Size: 30.00 (13 1/4)
Movement Height: 7.9mm
Seconds: Small seconds at 9 o'clock position
Chronograph: Yes
Sub dial position: 6,9,12
Date Position: 3 o'clock
Date wheel Colour: White with Black numbers
Pusher Position: 2 and 4
Hand size - Hour: 2.00mm
Hand size - Minute: 1.20mm
Hand size - Central Second: 0.20mm
Hand size - Sub Dial: 0.20mm
as you can see, no difference to A7750
Importr
1,799
447
You mean....like this? :)
I kept the a7750 though, as it was working fine.
As Taka said, the only hand that needs attention is the large chrono seconds. You can enlarge the tube EVER SO SLIGHTLY by tapping down on it with a fine sewing needle.
:wink:
chillininla
112
Wow!!! :shock: :shock:
That's nice!... I can't wait till mine's done now.
BTW did you have the hands and pearl relumed to match the Gen dial, or is it close enough to leave as is in your opinion?
Importr
1,799
447
Thanks, the photos don't truly show it, but the gen dial is a lot smoother and crisper than the rep dial.
The hands are standard for now, and the lume is pretty crap.
I've got some Nitrolume ordered, so hopefully I'll have a decent set of lumed hands on it soon! :)
cc
434
California
The seconds hand on the A7750 28k bph movment is slightly different in size. I believe the seconds hand needs to be broached to fit.
cc
guru
11,730
1,450
cc
you mean from the chrono?
