Just had my first ever watch delivered today. It's a Tag Grand Carrera Calibre 36.
Looks good and appears to be working OK. Couple of questions though ...
The instructions on Watcheden's website for setting the the time and so on say that you need to unwind the knob a little to unlock it, it pops out and then you can wind the watch or pull it out a little further to set the time. Well, mine doesn't need to be unwound a little and you can't push in and wind it tight to lock it. The knob just spins around in either direction, appearing to do nothing. You can pull the knob out but it is EXTREMELY stiff. When you pull it out you can set the time so no big deal really but, is this normal for these watches?
Second thing, the bezel can be rotated but only in one direction. Doesn't really matter but I'm wondering if this has some other function that's not obvious other than just being able to rotate it.
The inner bezel (if that's what it's called) rotates with the small knob on the other side of the watch.
The stopwatch buttons appear to work as you would expect.
If this is all explained somewhere, just point me to it.
Thanks.
Thanks.
