First order wit Puretime, Omega Speedmaster MoonWatch
Restani
11/6/24
11
Hello
I’m new in the Replica Watch industry and after doing some research, came across the Speedmaster MoonWatch OMF SS Sapphire Crystal Black Dial on SS Bracelet.
I just sent an order and I will share the details!
08-06-2024: Checked availability
09-06-2024: Available with 2-3 weeks for factory supply and 2 weeks for shipping
10-06-2024: Placed order on website
11-06-2024: Payment sent
I’ll let you know with any updates.
puretime
Trusted Dealer
Trusted Dealer
16/3/06
14,905
5,527
Thank you for your order. We will confirm the payment and process your order as soon as possible
Dote_Anek
My world happens to be outside the box.
6/11/22
39
50
It is actually a very nice watch. Enthusiasts will no doubt point out that the sub-dials are too far apart compared to the gen. Never mind that. Enjoy...
Reactions: Restani
Restani
11/6/24
11
Very good eye indeed.
I had a video sent of the hand and complications moving and everything seems in order.
Thank you both for your input.
TheBigJS
Play nicely
1,100
2,107
It's not the end of the world unless you're a full on rep geek, it's not going to show on the wrist to the average watch enthusiast.
Speedmaster reduced, gen obv.
People worry too much, no one normal is spotting it.
Restani
11/6/24
11
Did you get tracking yet? Doing my first order now and awaiting tracking. PureTime has been amazing.
Got tracking some days after and 2 weeks after I received the watch. Watch feels very good and premium. Im enjoying it.
Two minor things I have noticed, besides the subdial placement (see above):
- The crown has a lot of resistance when winding, but searching the web it seems like it is a factor that varies from watch to watch
- The spring on the start/stop pusher of the chronograph feels a little bit more flimsy than the reset pusher which feels tight and sturdy.
Regarding the team at PureTime, it was a pleasant experience. No issues at all.
Good luck with your order
Restani
11/6/24
11
Exactly. It looks good for me. Feels good to wear and compliments a nice outfit. I'm enjoying it! 😎
Restani
11/6/24
11
What do you recommend I can do to reduce the resistance when winding the watch? It seems to be getting worse day by day.
I tried letting the watch run out and then winding, without any change.
puretime
Trusted Dealer
Trusted Dealer
16/3/06
14,905
5,527
I am not exactly sure how much the resistance is with your watch but it's maybe over winded or maybe crown issue. I suggest to check with a watchsmith first.
j-unit
940
1,758
CH🇨🇭GER 🇩🇪
There should be no need usually to wind the watch 'day by day' manually while wearing it. The rotor should do the job. You may only use the manual winding when the watch stopped before.
TheBigJS
Play nicely
1,100
2,107
This is a Speedmaster, rep or gen they're manual wind only, no rotor.
Mines a ball ache to wind, it's not hard to turn, it's hard to grip, you can't just wind it by running your forefinger on the underside of the crown like any normal watch, because you wind the crown fully pushed in (it's not screw down) the crown guards are in the way quite a lot.
Reactions: Restani and j-unit
Restani
11/6/24
11
It is quite a lot, to the point where I'm pinching my fingers tightly to get the crown to wind. I experienced the crown to be turning back, but apparently it is a protective mechanism against over winding.
After 7-8 turns I have once experienced the crown to feel as if it is locked and won't go further. I did not try to force it.
As it is a manual wind, 7-8 turns is not lasting much, and I have experienced the watch stopping a couple of times.
Restani
11/6/24
11
Furthermore, this is only happening when winding the crown clockwise. Anticlockwise is buttery smooth and when setting the time (crown pulled out), also smooth.
I would have expected the same feeling when winding the watch.
