[First Order] GMT II 126710 Pepsi Jub & Portugieser Perpetual
Kayzen
15
Hello All,
This is my first order form Steve.
[11/5/2024] - Order Date / Paid
Will keep you guys posted on the update.
Cheers
Kayzen
15
2nd Update
[11/10/2024] QC send for the 2nd Watch IWC Portugieser Perpetual Calendar 5033 42mm
Kayzen
15
3rd Update -
[11/10/2024] Requested to adjust LIFT to 55* instead of 59* and change Amplitude from 287 to 292 on the Rolex Pepsi BLRO --
QC approved on both watches. Waiting on shipping tracking details.
Kayzen
15
Hour hand on the IWC looks oxidized/dirty, are you happy with that?
Thank you for noticing, I just noticed this after you brought this up. I have sent a msg to Steve. Thank again for watching out! :)
Kayzen
15
What do you mean by that?
Rolex watches typically have a higher amplitude than other brands because of their efficient movement design. Amplitude is the angle created by the balance wheel's swing, and a healthy amplitude for luxury mechanical watches is between 270 and 310 degrees.
Hope this helps :)
j-unit
794
1,447
CH🇨🇭GER 🇩🇪
Hope this helps :)
I don't get it why you would request to change the amplitude. For my understanding, you can not tune it to a specific value as it is purely a result.
Kayzen
15
From what I read and pls correct me if I am wrong, It can be adjusted.
j-unit
794
1,447
CH🇨🇭GER 🇩🇪
I was not sure want you meant first, but no, you can't request a specific amplitude. It is an result indicator, not an input.
Reactions: Kayzen
Kayzen
15
"You can adjust the rate of a watch using a timegrapher and the regulator. However, you can't adjust the movement of a watch to increase amplitude from the mainspring barrel."
Kayzen
15
Thank you for this resource.
VintageVibes
very clean pepsi!! :love:
gl with thw iwc hopefully it will come through ok
