First attempt at gold plating
swany100
92
41
Hi all hope your all well after stripping the pvd coating from a VSF bluesy with 18k gold plate as you can see from the pictures the shade is slightly darker than the GEN link
So my question is has anyone tried going to 14k with any success on shade or is it too pale any suggestions are welcome
Slugger
Absent Minded Professor
2,204
1,834
Upper is rep. Bottom is gen?
18k is 75% gold and the other 25% is a mixture of other metals. As such, you can have 18k yellow, white, and rose gold depending on what makes up the 25%. Rolex has their own proprietary alloy so getting an exact color match, while theoretically doable, is going to be a very deep rabbit hole.
Looks great by the way.
zinduna
1,167
698
I cant speak to 14 or 18 carat gold tones but I have a plating setup (Jewel Master Pro) that I use to white gold plate my watches. I have found different tonal results can happen depending on the temperature of the mixture, how long it's exposed, etc. For me it was a matter of trial and error (and detailed note taking) to figure out what works best. Once I got it dialed in, I was able to achieve consistent results.
swany100
92
41
Thanks for the reply I’ve read that. I’ve got some 12k samples on the way and hoping that there close and will go from there
I have recently found out that Rolex start out with a 75%gold and 25%silver no copper and then add various hardening powdered alloys and ceramic to bring the hardness which in turn changes the colour slightly again
zinduna
1,167
698
I found these technical data sheets helpful: https://www.goldplating.com/pages/technical-data-sheets. Follow the instructions to the letter for best results.
My jam is patek reps, particularly white gold ones, and I learned that their makeup is 75% gold, 12.5% silver and 12.5% palladium. Different brands use different alloys. The best way to replicate this on a stainless steel base is: 1. electro cleaner, 2. trival gold strike, 3. 24K gold plate. Then, woods nickel strike followed by palladium. This gives a warm gold base over which palladium is applied. Some skip the gold underlayer, which is a mistake. Another mistake is to use rhodium to plate -- PP stopped using rhodium in 2006. Weird watch arcana :ROFLMAO:
derjenigewelcher
Watch enthusiast
9,966
13,736
Switzerland
Great work. There are electrolytes where you take 24c gold and add em for making brighter. If you do this drip by drip, you cann achieve EVERY gold tone from 24k gold to absolute white gold. So just like cooking, make a recipie;)
swany100
92
41
Hi I’ve seen the gold brighterners but they only work in 24k soft gold plating and I’m using hard bright gold solution much better for watches and longevity I think I’ll see how the 12 k tone is and then make a disision on which way to go
swany100
92
41
Thanks for that pal I’ll take a look
derjenigewelcher
Watch enthusiast
9,966
13,736
Switzerland
IMO flushing with 24k yellow hardgold first and over THAT plating with soft gold is the way ;)
davelister
501
662
I've been looking at the Jewel Master Pro for replating vintage watches. How are you finding the system?
zinduna
1,167
698
I bought mine from a Craigslist seller; it's the only one I've used, so I can't compare it to anything else. It does a great job, and the manufacturer, Goldplating.com, provides tech support and detailed YouTube videos. I buy my chemicals through them too, so all in all, it's been an excellent system for a hobbyist. Once you get your formula figured out, it's pretty straightforward.
davelister
501
662
Fantastic - sounds like a winner for the price.
Reactions: zinduna
Pinion Minion
2,639
10,437
Texas
That looks pretty damn nice- well done!
Lets see some natural sunlight comparison shots
davelister
501
662
I have a vintage gen I want replated and I was considering sending into goldplating.com - trying to estimate the surface area is a huge pain though.
