Fantasy model?
audace
1,508
It's not a fantasy model that's for sure. As for accuracy to gen, generally H factory pams are pretty much on the dot (check with your dealer). As for leather strap, again, check with your dealer. Shouldn't be a problem.
You can give Lay a try, www.replicamake88.com . He's the only guy I go to get my watches. Reason being despite my anal requests he still delivers. That's what I admire about Lay, his impeccable service. You won't go wrong with him.
HPoirot
483
42
Cool, thanks!
I've actually had quite a bad experience with Lay.
So will probably go with a different dealer for now.
If i get the bracelet version, can i change it to a leather strap easily?
audace
1,508
Cool, thanks!
Oh what a pity.. Oh well.
Yes, all you need is a proper screwdriver and you're pretty much settled
Stromtrooper4
316
This is a Fantasy watch the only sandwich destro 44mm is the 26. The CG is the wrong up as well. Its cheap but you can get a lot better for a little more $
