ETA 2824-2 Manual Wind Malfunction
SS72
3,126
11,635
Australia
I have an ETA 2824-2 in a watch with the dial, hands, etc, fitted and cased. And it has a manual winding issue.
I'll be sending it off to get fixed, but am curious about what the cause could be, if it's possible to diagnose from the following:
1. The movement auto winds and runs perfectly - amplitude, beat, clean readout with no noise.
2. Date setting and time setting positions engage properly and function normally, including hacking.
3. When unscrewing the crown to move the stem into winding position, there is no click/snapping into that first position.
4. In that position, the crown physically cannot be turned clockwise without significant effort.
5. It does not wind manually, and after a lot of effort, it snaps forward one click, and that cycle repeats.
6. Turning the crown anticlockwise feels normal.
When screwing the crown back onto the tube, it does screw all the way on, and it threads smoothly, but a lot of effort is required. And it sounds like it might be winding at that point.
ward1991
3,486
3,552
Rust Belt
[Record scratch, Freeze frame]
"Yup, thats me, keyless works. You're probably wondering how I ended up like this."
Cue Baba O'Reilly
It's your keyless, easy to fix if youre familiar at all with taking apart watches, possibly a worn member of the family but likely it all just needs to be reset. The works reside under the dial where the stem goes into the movement. They're responsible for hacking, controlling the stems position, winding setting, quick set date and time set. All the clicking you hear when operating the crown in and out is these parts interacting with each other.
Most of the time when the stem is removed from the watch and the wrong size screw driver or tool is used to depress the stem release it puts the keyless works out of commission. It can also happen from regular use of the crown or heavy handed use of the crown.
Simply put, the keyless works are the crazy ex of watch parts.
ward1991
3,486
3,552
Rust Belt
P.s. I really dig the update of your avatar to the Unforgiven pic! My favorite movie of all time.
There wasn't room for the both of us in this here town!
SS72
3,126
11,635
Australia
Thanks mate. I ruled out the keyless in my mind because all other positions are engaging okay, and I've typically found the stem spins but the winding doesn't engage if it's the keyless. I hope that's all it is.
Yep, I had to change my avatar pic. But no way was I not going to be Clint. Also my favorite movie of all time, sine the day I saw it in the cinema. That man is one of my heroes.
Reactions: ward1991
SS72
3,126
11,635
Australia
It turns out the manual winding issue is due to a combination of two things:
  • Auto winding reversing gears incorrectly oiled and/or gunky, hence manual winding has more friction than normal; and
  • Stem is too short, so screwing down in first position instead of winding
Replacement of the reversing gears has been done and manual winding is much smoother now. A replacement stem is on order.
@tongsui is making everything right again!
maker99
61
40
I was typing the stem issue to you and to tell you that the reversing gears are probably not great but ok if auto winding is ok. do you want me to send you a few stems to keep and cutter to borrow? No charge of course. Hope all is well!
Kyle
Reactions: SS72
SS72
3,126
11,635
Australia
Kyle
Kyle, that is a very nice offer and greatly appreciated.
The reversing gears and steam were replaced in July last year and the watch has been operating beautifully ever since.
It turns out the movement is a 2824-1, not 2824-2, and the stem is slightly different. I do have a spare stem on hand in case it's needed in future.
Thanks again mate.
Karbon74
Pika Factory
12,301
25,944
EU - Kalos Region
This is exactly what happened on my 1016.
I was too lazy to service the auto winding just now so I just replaced the mvt with a PT5000 while taking off the calendar works and erasing the ghost date with a 2 position spring.
The PT5000 winds sooo much smoother.
I will switch to this mvt for future now instead of the Seagull
Reactions: SS72
maker99
61
40
Contact me , you dropped the clutch
