Dropped my 113.....
WatchDude13
795
I dropped my Davidsen 113 on my desk (fall of about 2 feet) and it killed it.
He states it is a Swiss 7497 movement, anyone know if it could be a simple fix or what movements fit his case (that I can buy state-side)? I want to used the same dial and hands without any mods as I'm not much of a tinker-er with watches (I can open the case and get around inside, but not very well).
Thanks,
WD
D
d4m.test
Guest
when you say 'killed' what do you mean?
has it simply stop running...a drop sometimes will disengage the crown from the movement, so no manual wind...make sure its a simple fix first...FYI...this has happened to me before on my 036. The watchsmith was able to fix it pretty easily.
watchlover
1,199
Watchdude:
ETA 6497-1 is probably what you want :) You hafta get someone to transfer the cannon pin and the plates to the davidsen movt :)
copy and paste to new browser window to avoid detection:
http://www.ofrei.com/page206.html
..sells them
D
d4m.test
Guest
don't be sad just yet...that is what happened to mine...it will wind wind wind...but then nothing...
Try to find a small, local watch shop ...doesn't have to be a fancy watch guy just anyone that is
proficient working with 6497 which is such a common movement...
my guy works for $40/hr...it took him 30 minutes...it cost me $20.
if ur in the NYC area i can recommend him to you...otherwise...give vaccum a holler..
THOR509
686
wow ! that skelleton 6497 is gorgeous ! i want one in in a 3646 pillow case ! all my watches are fantasy anyway. i have a thing about fakes :) i like the look of pams but couldnt care less about haveing a branded one :)
lumpyone
299
watchlover said:
Watchdude:
..sells them
man that site is pretty amazing. if i was capable of working on anything smaller than a 302 v8 i would try to build my own watch.
:D
