- 16/3/13
- 1,056
- 377
- 0
The purpose of this thread is to hear some opinions about the SevenFriday P2B/03-W ‘Woody’ NFC V6F Best Edition quality and similarity to gen.
Movement: Both gen and rep powered by Miyota 82S7. This is a rare situation that you get the actual movement of the gen
Dial: rep on the left, gen on the right
The gen lighting is much darker to it is hard to compare color (and also highly photoshopped) but i could not spot major tells/
Case: both gen and rep declare the same case size
Back case:
The back case is a big tell, it seems much lighter. I think it is a philosophical discussion if a back of the case should be considered as a tell at all. since it is not visible when you wear the watch (like in many other NWBIGs that the movement is different but not consider as a tell since it is not visible)
The strap:
It is hard to tell from the photos, but based on my previous experience, I belive that the strap will not be the same qulity and need to be replaced...
As a complete noob I'm not here to write an opinion but to start a discussion and to hear your opinions.
Thanks!
Back case:
The strap:
Thanks!
