DOA Chrono Evo Ultimate from Andrew
w2w
Had a Chrono evo Ultimate delivered from Andrew in 6 days to the UK [happy with that] But it wouldn't start, I then wound it for 30 turns and it kicked into life, I put it on and wore it overnight [to charge it] and took it off but it died within an hour. So I done the 30 tuns again and again it sparked into life but then noticed that after about 2 hours it had died WHIST ON MY WRIST. By this time I was very concerned and Andrew said to take it to a watch repairers and get him to tighten the Winding Rotor Screw, well I did and he told me that that wasn't the fault, that the fault was more [in his words] "more terminal than that".
Just wondered if anyone else on this forum has had this problem before?
T@H
21
No...My BCE came fine...the only issue was when I re-sized it, the screw head fell off....but it fell of when I had it back in place...very small screw head obviously; i just put a smidge og glue and it's back in place and cannot be seen.
Andrew is a good guy, keep him informed on your outcome...maybe have it fixed and see if he can credit you on future purchases if the cost is higher than expected.
Just a thought.
w2w
Just a follow up on this. After trying a few things Andrew said he'd send a replacement and I needed to send it back [which I did] Today it turned up, working fine and I don't think the one I'd sent back has arrived there yet.
So very happy with the service from Andrew and have another 3 in transit from him
