DLC coated with Yellow face.
FastPaced
Preformer
26/2/17
1,541
130
So I was wondering what DLC coated with Yellow face Breitling (not with A7750) Rep is considered a super Rep? I have read about different models, some seen to be fantasy models and some the Gen does exist. So what do you guys think?
Smpfan
996
303
G-fac Avenger Seawolf II DLC with yellow dia.
FastPaced
Preformer
26/2/17
1,541
130
I thought these Seawolf II have wring case shape and were not considered that close to Gen?
ernien
785
163
Ontario, Canada
I have one and it's quite impressive. The GF version has the correct case shape to gen. They clearly had the gen because not only is the case correct (which is noticeable different from the Seawolf I case) but they also got the Cobra yellow colour correct.
The DLC finish is the best I've ever seen in a rep which is the same as the GF Avenger GMT. It has the amazing pencil lead colour with a sheen.
The bezel is firm and solid in its rotation and clicks with no play.
The pearl could be a bit less white and more pearlescent, but pretty minor.
No regrets buying this one!
Reactions: KJ2020
FastPaced
Preformer
26/2/17
1,541
130
Wow looks Great! I definitely like the brighter yellow better than the Seawolf I. I have a Seawolf I but I just don't like the dull yellow. Question, do they (GF) make this DLC yellow face version with number makers instead of the lines?
ernien
785
163
Ontario, Canada
GF only makes the DLC Seawolf II in yellow with stick markers, and the gen only comes this way too.
With the gen, the Seawolf II yellow dial with numbers only comes in non DLC.
GF hasn't released this one yet, only the black and grey in non DLC.
FastPaced
Preformer
26/2/17
1,541
130
I see. Even with a stick markers I think I like it better than my H Factory Seawolf Yellow face v2. The dull yellow is OK, but this brighter yellow, especially on the DLC case really "pops" in my opinion! I may just have to buy this one. Do you know if the sell on the Pro Diver III bracelet?
ernien
785
163
Ontario, Canada
I've only seen TD's list it with the black nylon strap with DLC tang buckle, but might be worth asking if they can change it.
You won't regret the purchase, the contrast between the bright dial and dark case is stunning!
Smpfan
996
303
Buy a gen pro-III diver rubber and you're done. It's not so expensive but outstanding quality.
I'm waiting for the yellow faced non DLC version with numbers. Really enjoy this version.
But your older Seawolf yellow dial is great, too. H-fac? I've got the grey one. Superb rep.
And avoid those ANF Breitling reps. They are pieces of sh**!!!
Reactions: tkingjr
FastPaced
Preformer
26/2/17
1,541
130
My older on is an H factory one, I do like it but this brighter yellow dial really grabs me. I put a Gen Pro Diver III strap on theolder yellow face seawolf.
The only problem with the Gen Pro Diver III strap is it doesn't have a DLC buckle on it. The rep Pro Diver III bracelet that comes on the GMT has the dlc buckle.
Thatwatchguy
6,987
4,519
Nice B collection, I've got the gmt on the way but would love to get the cobra yellow dial DLC but not sure how the date font compares to gen - how is yours?
FastPaced
Preformer
26/2/17
1,541
130
So I have a question. Is your GF Seawolf II bigger then your Seawolf I? Mine came in today and compared to my Gen Seawolf I and H Factory Seawolf I, it is a lot bigger. I love the watch, just trying to figure out if the Gen is this big or not.
nanoman
826
192
PNW
The Gen is 45mm with ~18.5mm thickness.
Could you post a pic or 2 of the watch . There seems to be a dearth of G-Factory Cobra dial DLC watch pics.
ernien
785
163
Ontario, Canada
Well dimensionally they appear to be the same. However, the II has a taller rehaut giving it a deeper feeling as the dial is sits down further from the crystal than the I.
This combined with the wider bezel gives it a bit of a bigger feeling.
FastPaced
Preformer
26/2/17
1,541
130
I will measure both my Seawolf I and Seawolf II and post the number maybe you could check yours to see if they are the same.
I want to be sure the TD didn't accidentally send me an AN version by mistake. I checked the movement, it is the silver one with engravings. From the pictures I have seen, the AN Factory uses a gold color movement with no engravings. Does anyone know if the AN factory ever puts the silver one with engravings in it?
ernien
785
163
Ontario, Canada
Well the differences between the GF and the AN are pretty significant and should be pretty obvious. AN is quite low quality, really dark, and they didn't even use a Seawolf II case.
If you look at the back side, the GF/gen have notches between the lugs, and the underside of the lugs are smooth. AN is not like this, they used the old Seawolf I case.
Also, looking from the side, the lugs on the AN swoop down more (like the Seawolf I). The GF/gen Seawolf II lugs are less dramatic.
GF top, AN bottom
FastPaced
Preformer
26/2/17
1,541
130
Perfect, Thank you for the pictures! So they did send me the right one, the GF. This one is nice, but I have to say I like the Seawolf I better. I just wish the Yellow on the Seawolf I was this nice cobra yellow like the Seawold II. My Seawolf I is the perfect fitting watch for me. The Seawolf II just seems a little big for the pro diver III strap
Alex-mtl
9/12/15
13
Beautiful watches you got there mate! Is your GMT a GF V2?
Marbe78
298
143
Spain
I like Seawolf II yellow dial with steel.
any important differences with the gen?
i want to put it a gen rubber strap
good combo for the summer
