DIY Pre V box
mojojojay
1,122
did some upgrade on my pre v box .
its a shabby job , will find better materials to do it again .
some comments on how to make it better .
chromed.
2,460
awesome stuff, jay! i'd change e latch&mayb age e box a lil.. re-varnishing might be another option..
just my 2 cents :)
PS: is tt MEGAN FOX in ur avatar!?!?! H-O-T-N-E-S-S ! ! !
mojojojay
1,122
I more concern about the interior , need to find good quality material . Any ideas where I can find some in sg ?
seriph
1,965
164
Any pics of originals or are you justtrying to make a nice stand alone case?
Possibly consider using dense foam like that used in photography cases. Then, using spray adhesive or dbl sided tape (which i found a lot easier and more forgiving) to adhere black felt to. For the sash you could again use the felt but dbl it over (joined in the centre along the length of the back) so it has a little more substance and finished edges. Anyway, just a couple of ideas.
seriph
1,965
164
If synthetic, that grey material is called suedelux in Australia .... was made by Nylex but no idea who might make it now .... automotive trimmers and general upholsterers should be able to supply it - or considering it is such a small area, you could just use real suede and have the sash stitched by a place that does garment alterations .... should cost very little as it is so small. Show them the original photo and tell them to make it the same and they could do it in moments.
I will post a couple of my 'box' projects when I can find them on the PC - not for watches though (yet) - for pens
seriph
1,965
164
These are a couple of projects I did - one for my mate's 50th and one for my wife as a gift.
seriph
1,965
164
... and the wife's gift. I didn't make this particular box as I found a nice one in a thrift store for $4 and considering the one above took around 30+ hours (all hand work) to get from raw wood to finished product, I was a bit over it all.
Anyway, this one was bought then modified (full interior and images created, then added)
I sourced the images online as well as the quote and signature (lifted from a signed letter by Ingrid) added the Montblanc logo discretely and voilà.
The fabric for the insert is some suit material I got from a local fabric store (the one above is red crushed velvet from the same place) and I made 2 triangular 'blanks' from 3 or 5 mm MDF to go under the fabric .... I was going to use thin upholsterer's foam under the cloth to give it bounce and importantly, retain tension to keep it all smooth as well as make the edges 'softer' but the foam was too dense, or resilient I guess you could say - so I went with dacron fibre also from the local fabric shop. I also had some sticky-back black flock fabric (Like Contact if members have such a product in their countries - sold by the foot or metre on a roll in a stationery shop) and I added that to the 'gap' in between the two triangles ..... this is all really quite challenging to explain!
Anyway enough of my BS - here's the result .... turned out nicely.
BTW the "MB" is a high-end replica of a Montblanc Bergman La Donna.... not your usual crappy one.
The other pen is a hand made item, made for my mate's 50th birthday, by Curtis pens in Bairnsdale Australia (Australia's only professional pen maker) - David was born in that region and the wood for the box came from his family farm, coincidentally milled and stored since 1961, the year of his birth.
He was blown away by the gift - the wife was happy with hers and uses it daily at her work ... she gets lots of positive comments.
end of my over-long sermon!
chromed.
2,460
can try Spotlight in Plaza Singapura..they have a wide range of fabrics there.. or parts of Little India & its vicinity.. quite afew fabric shops there as well..
