snielsen said:http://replica-watch.info/forum/viewtopic.php?t=15443 ..........check with River he may still have these...I don't think you can do better
Epoch said:We could all use a box like you describe. So I take it you have the 'bug'?
darksideuser121 said:Take a look at this one http://cgi.ebay.com/Watch-case-box-for- ... dZViewItem
snielsen said:You have to be very careful because most if not all of the clear or glass top watch cases do not have the clearance for the Panerai watches. Good luck in your search.
dawg said:snielsen said:You have to be very careful because most if not all of the clear or glass top watch cases do not have the clearance for the Panerai watches. Good luck in your search.
True this is a tough one. I want to display one of my Fiddy's to save for the future. So maybe anyway i can put it under glass would work. I will keep on searching.
Mojua said:dawg said:snielsen said:You have to be very careful because most if not all of the clear or glass top watch cases do not have the clearance for the Panerai watches. Good luck in your search.
safe queen...what the???
dawg said:Mojua said:dawg said:snielsen said:You have to be very careful because most if not all of the clear or glass top watch cases do not have the clearance for the Panerai watches. Good luck in your search.
Huh :shock:
Mojua said:dawg said:Mojua said:dawg said:snielsen said:You have to be very careful because most if not all of the clear or glass top watch cases do not have the clearance for the Panerai watches. Good luck in your search.
Huh :shock:
"I want to display one of my Fiddy's to save for the future."...the watch my friend...
dawg said:Mojua said:dawg said:Mojua said:dawg said:[quote="snielsen":7k861634]You have to be very careful because most if not all of the clear or glass top watch cases do not have the clearance for the Panerai watches. Good luck in your search.
Huh :shock:
Mojua said:dawg said:Mojua said:dawg said:Mojua said:[quote="dawg":1jsaisrp][quote="snielsen":1jsaisrp]You have to be very careful because most if not all of the clear or glass top watch cases do not have the clearance for the Panerai watches. Good luck in your search.
Huh :shock:
dawg said:Mojua said:dawg said:Mojua said:dawg said:[quote="Mojua":4g85dldn][quote="dawg":4g85dldn][quote="snielsen":4g85dldn]You have to be very careful because most if not all of the clear or glass top watch cases do not have the clearance for the Panerai watches. Good luck in your search.
Huh :shock:
dawg said:darksideuser121 said:Take a look at this one http://cgi.ebay.com/Watch-case-box-for- ... dZViewItem
Do you think it measures large enough for the large fiddy?
