Differences between 005 and 111 ? Look identical.....
jpohl402
5,327
17
(The manufacturer doing R&D) makes an entire new watch with that small change?
So those interested can choose between symbol or no symbol on dial ?
jpohl402
5,327
17
OK thanks for the clarification.
I remember the differences between dials, but not which is which.
Is sausage the full-lume "plate" underneath - and dial with cut-outs laid on top?
With sandwich being raised, painted on numerals?
Thanks
karesz501
1,985
European Union
Thanks
No, just the opposite.... Sandwich meaning the lume in the dial and movement sandwich. Sausage, since the printed lume looks as a sausage because of the curved numerals.
mysterio
9,794
866
And to answer your other question, the PAM104 is a very good rep. Using the 7750 adds to the accuracy since the 6497 is a manual movement and totally inappropriate for an automatic watch such as the PAM104.
karesz501
1,985
European Union
I think the question was if the pam104 with a7750 is more acurate to gen then the 005/111 with a6497. And as I've said, its all written clearly in the PAM guide, just to avoid commenting these over and over again in a separate thread.
@OP: please use the guide mate, you'll find all the answers there!
jpohl402
5,327
17
That's all I wanted to know. Taking all figures into consideration/using accurate movements, etc - how close the 104 was to genuine - i.e. a "good rep or super rep" which has been answered by you and also the Pam guide ALE posted - thanks.
Secondly, these each say "best version."
One is obviously Noob, is the other HFactory ?
I posted above (HFac?):
http://puretime.co/product/pam104-i-11-superlumed-best-edition-on-black-rubber-strap/
And the Noob:
http://www.puretime.co/product/pam104-n-11-noob-best-edition-a7750/
Which has better lume???
Lastly, in photos the numerals almost appear yellow-ish colored (like lume color) - is this true in real life because I believe the PAM005 and PAM111 numerals appear A BIT MORE white-ish...? Thanks gents
ALE7575
Section Mod
19,846
423
Hi jpohl
You should make some homeworks before asking such a questions
If you read the PAM GUIDE, you can learn what is a Sandwich and a Sausage dial, the differences between a 005 and 111 are perfectly explained, you will learn that PAM 104 is an automatic watch (no 6497 possibilities)...
And you can see too that the H maker and Noob are First Class replicas with very good quality and pending definitive evaluation as Super reps.
In some days I will start a thread to evaluate these two replicas. Please wait for the results. You will get all info there.
ALE
maccaz
Is there a similar PAM with OP logo and sandwich dial?
Ruski91
3,178
102
Please check out the PAM excel spreadsheet. You will be able to filter on catagories that you want to determine if a rep watch exists. Once you do this you can compare it to the PAM guide and see for yourself it this is a good rep or not.
ALE7575
Section Mod
19,846
423
Perfect answer!
Thanks
ALE
