Dial Scratch Removal on a sunburst dial?
McPwn
291
116
Has anyone attempted to remove fine/hairline scratches on a modern Datejust dial? I accidentally made a small mark on mine while trying to get a stain out ironically, which can only be seen up close. It seems like these dials (datejust 41 silver dial) have a top layer of clearcoat, wondering if theres an easy way to buff these out? Do those Auto polishes work?
37,514
80,096
I've gotten a lot of different marks off dials but never a scratch. Maybe sacrifice your rep dial to testing some products?
McPwn
291
116
The scratch is very small, but if its lacquer coated, I'd think you should be able to apply some gloss clear lacquer over it and buff it down. The rep dial is probably made a different way so hard to say if the same process would work on both. The Gen has a thicker coat on it, whereas the rep seems like a piece of plastic.
NCRich
Raddave's favorite
3,247
11,356
Its harder to do on a dial with indices because you have to take them off. You won't buff that out. I have removed scratches on vintage type dials but you can sand and recoat those easily. That's such a small scratch..........
Reactions: KJ2020
Joyousdooby
196
27
Hey sir! Sent you a PM about a custom vintage GMT master, just making sure you see it!
