Dial questions
Drr80
515
102
El paso, TX
I bought this dial its 35mm. I was planning on putting it in a 111 but i dont want to changed my bk noob v4
What other pam cases fit 35mm dials? Its for a 6947 obviously
Sent from my SM-N960U using Tapatalk
kilowattore
14,160
6,866
As far as I can remember luminor 44 cases take 34.5 mm dials, radiomir 45 take 37 mm dials.
Vonn
268
36
Luminor 44mm Case and Radiomir 336/337/338 case.
Vonn
268
36
Will only fit a radiomir if you want a coin-edge dial backplate and use a H3 hourwheel/Minute-Pinion in combination with Nightwatch tall barrel handsets.
Grimlocktime
DO NOT TRADE WITH ME
3/5/13
3,031
257
I believe the only modern Radiomir dial with CG is the Egiziano.
