- 18/7/15
- 565
- 103
- 0
Hi Guys,
Need some advice. Received PAM 232 and didn´t see it at first, but looking back at the QC pictures I noticed that the dial seemed misalligned i.e. not centered, noticable at the logo, and numbers. Like I said I didn´t see it at first.
After receiving the watch I noticed the hour hand was bend/pointing upwards which bothered me (I see this quite often btw, even in gen´s). Dealer offered to send it to his watch guy at his expense, but I decided to do it myself, I mean sending back and forth a watch to bend down the hour hand 1mm seemed a bit stupid.
So I ventured in my first attempt to take out a movement, with the help of an excellent youtube vid. Took movement out and pressed the hour hand carefully down so that it was horizontal in line with the dial/minute hand. Put everything back together and very happy about the result, and content with my achievement as a noob watch smit.
After been flashing it :B:, later that day the 232 was lying next to a 372 (good company btw) and all of a sudden I noticed the off centered dial. Dealer´s respons was that it was optical, but I disagree. Anyway, that´s not the issue as the dealer will come up with a solution one way or the other, at his expense.
My question is if there is a simple way to rotate the dial (a little anti clockwise) without having to take the movement apart? Is the dial glued to the movement? Or will loosening up some screws will do it? Any help is much appreciated. If to difficult I will follow dealer´s advise, weather he will offer to send it to the watch smit or sends a new movement/dial.
Thanks
Thanks
