Daytona Panda 116500 Clean V3 Deep crystal upgrade worth it?
dsk2004
26
21
Just purchased a Daytona Panda 116500 Clean V3 and was wondering if a Deep or Gen crystal upgrade worth it?
dsk2004
26
21
Bro srsly, do you know that you posted this in the eye candy and wristshot section? 😂 If so, why did you think that it was the correct spot to post this? 🤔
@P..DR..D Pls move this to the repair & modifications section when you get the chance. Thx bud!
Thank you for catching that, haven't posted that often. Will definitly pay attention to where I post next time.
Reactions: eBoy
Noggletime
34
11
I’m curious as well. I just ordered the CF v3 Panda and the deep crystal. Guess I’ll find out soon enough.
My understanding is that the crystal wasn’t upgraded on the v3, so it’s still using the same crystal as the v2 (which is cloudy).
dsk2004
26
21
I have the CF v3 Panda also and just ordered the Deep crystal from Xing_Patrick. I also purchased a press to do this, first time. I will post before and after pics.
Noggletime
34
11
I ordered my deep crystal from Steve, who offered to press it for me (so likely will only be able to post after pics).
Reactions: dsk2004
Goodlife
17/4/21
14
where did you order the CF v3 panda?
Noggletime
34
11
I ordered mine from Steve.
Any of the TD’s should be able to source you the watch.
DonkeyHoTay
Cockwomble Misfire Specialist
17/3/23
192
238
SE USA
Dang it! I did not realize Steve could mod watches I order! He just shipped me a clean v3 Daytona Panda and I didn’t think to ask about the crystal! Now I have to order a crystal too…. FACK…
Noggletime
34
11
If it makes you feel any better, I decided to not go ahead with it. He informed me the v3 crystal was already upgraded from the v2.
The crystal QC shots I received looked pretty clear to me, so I asked him if I could drop the request. He said he would refund me the price for the deep crystal. What a guy!
DonkeyHoTay
17/3/23
192
238
SE USA
That does make me feel better - Thanks!
Relos_Indios
157
152
Asia
Did Steve give any specifics on what those upgrades are on the xtal?
Noggletime
34
11
Any updates on this? Very curious to know whether or not you see a difference with a swapped crystal!
cyprusdaedalus
Wannabe Watchmaker
482
546
My repost from the deep thread on my install today:
Did my first one on my CF V3 Panda today. Have to say it does make a noticeable difference/improvement. Used this excellent tutorial (https://forum.replica-watch.info/th...t-guide-my-experience-guidance-only.10881737/) as it was my first time disassembling a Daytona bezel and everything went pretty smooth.
I found aligning the LEC on the crystal to be fairly hard as it was so hard to actually see the crown imprint against the white dial but other than that pretty straight forward. Had to redo the bezel press once as it got slightly jostled off center when placing into the press the first time. Take your time, protect all surfaces you can and you should be fine.
Only downside is I own 2 more Daytonas and a No Date sub that all need xtals now... damnnit.
Forgive the weird strap - waiting on my Oysterflex and CF endlinks for this one and didn't want to refit the OE bracelet.
CF V3 + Deep:
aHero
Watch Bro
4,455
6,604
CF V3 + Deep:
I just bought nine Deep crystals from Patrick including five for Daytonas. Glad to hear it can be done by a first timer!
aHero
Watch Bro
4,455
6,604
CF V3 + Deep:
Curious, did you remove the movement as per the guide? Seems unnecessary as the author does eventually admit.
cyprusdaedalus
Wannabe Watchmaker
482
546
I did remove the movement initially because I hadn't thought it through but yes I would agree it is unneccesary. You can bypass all of those steps and it would be faster and much less prone to mistakes or damage occuring to stuff.
Just press the bezel off, press the crystal out, swap crystal into the original gasket and place back onto the case, align LEC, and then press bezel back on. Doing it this way it probably would take 10-15 minutes to swap everything taking your time.
