Daytona 116500 Widgets for iPhones. *Revised*
M Scott
Daytona Aficionado
22/9/18
870
1,194
I have created two Daytona 116500 Watch Faces for an iPhone App called Widgy.
( Sorry but it won't work on Android phones )
The Minute and Hour Hands work to keep the correct time. The app is limited, so the Seconds and the Chrono don't work.
** I know this is a little off topic, but I hope that the Mods will allow it as I did put a fare amount of work into this, and would like to share it. **
Instructions for installing the App and then the Daytona Dials...
  • At this point, you are ready to set-up the Daytona Widget on your iPhone.
  • From the Web Browser on your iPhone, go to this RWI post and select one of the following links...
  • Click on the link and a message should pop up asking if you would like to open the Widgy App.
  • Tap Okay on the message and the Daytona Dial should appear.
  • You have the option to download both Widget files and then switch them to see which one you like best.
  • Tap the back arrow in the upper left corner to go back to the Create Screen.
  • Press on Manage, again from the Menu Bar at the bottom.
  • On the Manage Screen, in the Small Widgy Slots section , click on the first Small Widgy Slot.
  • Then select your Daytona Dial from that screen and then exit the Widgy App.
  • From your iPhone Home screen, tap and hold anywhere on the screen to get the Apps to wiggle.
  • Then press the + icon located at the top left of your screen.
  • Scroll all the way down, and then tap on Widgy
  • Select the small widget #1, and then click on Add widget.
  • Then you can move your Daytona Widget to the location you want and then press Done.
You can also install the macOS version of Widgy and use the same Widget files to put Daytona Widgets on your Mac.
BTW... I revised this with a new post because the original file hosting links were spam filled garbage. Sorry for any inconvenience that may been have caused.
nomana
549
202
Might be good reason for me to update firmware. Look real nice
M Scott
Daytona Aficionado
22/9/18
870
1,194
I tried looking into making an Android version of this, but it appears that you must use an Android phone, which I do not have.
If anyone has, or knows of a good Android Widget creating App, I can all the provide individual images of the Dials and Hands to put it all together.
Reactions: P..DR..D
P..DR..D
24,923
27,533
Éire
Thanks for looking into it :thumbsup:
Definitely subscribing in case another member has the tech skills to incorporate your cool widget into the Android platform.
EpicRolex
DO NOT TRADE WITH ME
31/12/20
51
17
Wow! This is a pretty cool widget! I'm adding it to my phone now. Good Job!
iang27
467
80
Sorted. I did have the app on but restarted my phone and it’s working now. Looks great.
