Custom 44mm PAM 2025 build
Belkin12
Supporting Vendor
26/10/12
340
1,250
Ukraine
This is a fantasy 44mm build inspired by the pam2025 Paneristi edition. This is not a rep or a clone of the gen but an absolutely custom and unique build.
In a nutshell:
- 44mm Luminor 1950 case. Aged gun-metal PVD coating.
- 3.4mm thick double dome crystal, no AR.
- Heavily modded crownguard and lever. The lever tip is oriented downwards, operates smoothly not flimsy. Engraved. Aged PVD coating.
- Modded display CB. Engraved. Crystal is engraved.
. New improved O-rings for better water resistance.
- Custom made brass sandwich dial. Grainy texture + navi blue gradient color. Cream lume and texts.
- Custom made 0.3mm brass backplate. Soldered dial feet for st2555 movement.
- Polished brass long double pencil hands. Cream lume.
- CP flattened and mirror polished.
- Oiled and adjusted st2555 movement. Calendar module removed. Brass plate on the rotor.
- Titanium lug tubes.
- 24x24mm light brown genuine leather strap. Size is 130mm x 80mm.
- 24mm screw-in (removable) buckle. Gently aged PVD coating.
derjenigewelcher
Watch enthusiast
9,893
13,592
Switzerland
You keep on going doing magic D.
Unbelievable. Thank you for beeing such a great contribution to the replica world. One of the greatest of the world if not THE greatest when it comes to PANERAI.
Slava Ukraini!
Panerai-123
15/2/24
11
You can always see top-designed watches with excellent workmanship from Belkin12 here. Thanks
icqmtl77
230
135
In a nutshell:
@Belkin12 You got to own a Belkin to know what is call a quality custom Pam!! Buy with confidence!
