Couple questions from a noob
nthusiastt
What's the difference between trevors 111h and dsn's 111h. Also I'm looking at a 217 as well and am picking up a strap. The site is asking if I need tubes but I'm not sure if this watch uses them.... Also just to confirm it's 26mm strap for the 217 and 24mm strap for the 111h, correct? I think the 111h doesn't require tubes, am I right?
Thanks in advance!
hooligan
8,332
Well, DSN uses some parts that no one else has or uses. That's good and bad. The big difference will be that the lume on the DSN watch will be much better.
Yes, the 217 uses 26mm straps, the 111 uses 24mm straps. You don't *need* tubes for any straps, but you may like them and prefer them. Up to you.
