Couple of 249 questions
Rocketeer
181
1. Has anyone got a source for a good domed plexi for a 249?
The DSN one is too tall as is, but maybe could be trimmed down. Any others?
2. Anyone have a good, reasonably straight on photo of the 'OP' crown used for the 249?
savage_here
315
I would say that cousinsuk would be the place for the plexi.
http://www.cousinsuk.com/catalog/4/0/2073.aspx
Here's the best pic I have of the 249 gen crown:
Hope this helps.
Savage
hooligan
8,332
What have you got going on, Rocket?!?!?! :twisted:
Yep, CousinsUK would be it.
I have a 40mm low-dome acrylic from them that I never ended up using. I can send it to you for testing/evaluation/whatever, if you'd like.
Aji
132
Hi Guys,
I'm in a Cali frame of mind too, does anyoe know how the trusty time 249's compare against the gen's, (for dome height).
Also changing out the dome and crown, how difficult is it ? Is it something that a novice should attempt.
Rocketeer, if you're doing a detailed mod we should talk.
Cheers
Rocketeer
181
Just finishing building a Kampfschwimmer for someone and it's given me the idea to try and do a better 249 as the ones I see about have problems that bug me.
I've got a Sternkreuz HWS400 in stock but was hoping to find something better. Tried HSW & AGT as well but they don't stock anything to suit.
I'll have a play at the crown as soon as I get a chance :twisted:
Aji
132
Any photos of the Kampfschwimmer ??
I like the cali dial, if you do start an 'ultimate' version i'm game. What's the standard of the ones you've seen 'out of the box'.
