Could anybody help identify this Panerai Daylight
c_hall100
El Presidente
4,331
13,467
Calling all Panerai specialists
Received this in a trade with some other watches I don’t know anything about it because I don’t know much about Panerai (yet)
The seller claims to have had it for a couple of years but can’t remember any details
wonder if anybody could shed some light as to the maker/model number etc
Love the watch feels incredibly well built just a bit snug on my wrist could do with another link I think
Anyway see what you think
Sent from my iPhone 11 using Tapatalk
Reactions: vcappp and dadog13
Offmybach
109
51
Yeah it's mine. I lost it earlier this year. Please send back. LOL
Sent from my SM-N975U using Tapatalk
Reactions: c_hall100
dadog13
5,092
3,253
PAM196 with A7753
Check Ale guide to identify factory and version. Might be Noob V1 but I am not 100% sure (would need to look into details)
macarone
5,170
3,023
CONUS USA
PAM196 with A7753
I respect your knowledge on pams, but isn’t the 196 on alligator?
macarone
5,170
3,023
CONUS USA
The 236 is different
PAM250 is same as 236 but without metal bracelet (with a strap, rubber, leather, canvas,...)
I’m still confused with the way they change metals and finishes to create a new piece lol. Both polished and brushed goin on has me thinking a Ti version?
dadog13
5,092
3,253
Take a close look at the dial, the main difference between 196 and 236/250 is there
mysterio
9,793
867
The bracelet throws off the would-be identifiers of the watch. Just remember, even in gen, watches that originally were sold with rubber or leather straps could also use bracelets (although in reps it's not fully guaranteed). But what remains fixed is the other details like the dial. It looks to be a PAM196 made by Noob in 2010 (so-called V1) based on the details. The presence of numbers instead of small sticks on the hour markers with numbers indicating the minutes at the periphery of the dial differentiates the PAM196 with the PAM236/250.
macarone
5,170
3,023
CONUS USA
m5smg2
6,522
8,536
It’s definitely a 196 on a bracelet. The gen was only available on a strap like the 188.
However, the date wheel looks a little sunken for a 7753. OP see if the date changes with the 11:00 side push button. If yes it’s A7753. If date changes from the crown then it’s standard 7750.
Also the 7753 has crown positions 0 for winding and 1 for time set. The crown has no second position for date because the date is changed from via 11:00 button.
c_hall100
El Presidente
4,331
13,467
Thanks all for your help and yes there’s a little button at the 11 o’clock that advances the date, when you pull the crown out it sets the time only
Reactions: vcappp and m5smg2
mysterio
9,793
867
If that's the case, then it may be a Noob V2 because the Noob V1 had an A7750 movement and so would have a faux date change button at the left side (not exactly at 11 but more on between 10 and 10:30 on the rep). The date wheel looked deeper though and the fonts looked thicker and so I came to the incorrect conclusion that it was a V1. Also A7753 movements had this common issue where the chrono hand @3 was wobbly and not centered at 0, which is apparently not present on your watch (this flaw is common but it does not appear in all reps) adding more to my suspicion that is was a V1. My apologies.
Reactions: vcappp
c_hall100
El Presidente
4,331
13,467
I think it’s my pictures as in the flesh the date wheel is hardly sunken at all so would agree it’s A7753
i know the A7750’s were much worse in that regards
Reactions: vcappp
Naths63
1,069
370
Can the wobbly hand at 3 o clock be fixed?...mines started to do it...
ssouthall6
3,539
1,563
No, they are all like that to a lesser or greater degree
Reactions: Naths63
