Converting my DSN 112 into a Destro
nielsen
1,216
Can I simply rotate the dial on my DSN 112 180 degrees and create a 'Destro'? Any technical problems doing so? I realize that it won't be a 'genuine rep' anymore, but I'm a lefty.
Exploder
1,039
Should be possible, remember to reset the hands. One potential problem could be the dial feet?
What happened to your Hugh Laurie avatar?
Cheers, Xplodr
oncyte
28/1/09
^^^ Xploder is right. The dial feet won't line up.
And if you seperate the dial and base plate you'll need to have the plate relumed after flipping it. Plus you will also need to get a Destro CG and you'll have to replace the movement bridge as the engraving will need to be flipped as well.
