Conversion of a second hand dial to a base dial.
pete2528ca
962
Hey everyone.
So I am gathering the parts to put together a daily beater vintage 47mm watch. Getting the lion's share of the parts is easy. $80 to Jackson for a complete watch, and then trading to other members for DSN crown guards and plexi's. I had a DSN solid case back already. So for the most part, coming together quite cheaply, so for a daily beater, awesome.
The problem is the dial. As we know there isn't much choice for base dials unless one spends about $80 (DSN) to $120+ (Southy).
BlueRadish was kind enough to bring me a sterile Jackson dial to tinker with.
Here is what it started it's life as:
The dial was stripped down to bare brass. I then made a mix of JB Weld, and brass dust that I got from sanding a piece of sheet brass I had kicking around. I used the 5 minute JB Weld. This was pushed into the second hand opening and the four hash marks surrounding it, and after it dried I lightly sanded it:
The underside, you may notice some engraving under the 12. I am having a local engraver pantograph it.
After sanding and cleaning I gave it a couple of light coats of self leveling primer, which will then be covered in flat black:
I will post some more pictures after it is painted and engraved.
Pietro
KBH
7,168
Kind of like working in an automotive body shop!
Except smaller.
frigpig
Ghost of Sales Mod Past
7,845
77
:watching:Interesting post. I'll be watching.
ThinkBachs
DO NOT TRADE WITH ME
9/2/09
8,915
87
Odd, you'd think that base dial would be a dime a dozen. Thanks for sharing this with us. :)
