I ve received too many PMs regarding PO modding. So, here you go...
1. Hour/Minute/Second Hands
The rep hands are too short and small. It's highly recommended to upgrade the hands. The lume of the genuine hands are much better.
Hands can be found on Ofrei
http://www.ofrei.com/page1122.html
My PO with genuine hands
2. Spring bar
The rep springbar is not tight enough. If you have a genuine omega, you can notice that the bracelet locks into the case tightly.
A pair of OEM spring bar is ~$8 + shipping
This is the pair I got from Ofrei:
http://www.ofrei.com/page957.html
OME-SPRING-BAR-04
3. Crown guard and crown tube
The crown guard of the 4th gen PO is a big give away.
You can fit in an OEM crown guard with an OEM crown tube.
Crown guard: Omega Crown 42184 Model 2209.50.00 Part number: 069 ST 42184
http://www.ofrei.com/page_147.html
Case Tube: Omega Case Tube Model 2209.50.00 Part number: 090 ST 1232
http://www.ofrei.com/page1115.html
The case tube is a little bigger. So you ll need to drill the hole of the case a little bigger.
Also, you may need an ETA-2824 stem. You can find it on ebay.
This guy is selling it for $2.80 on ebay.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0002348363
The stem is a little longer, so you ll need to cut it shorter.
I don't have a dremel, so I wasn't able to fit the tube in the case.
4. Bezel
The pearl is quite ugly on the rep.
You can find it at Ofrei:
http://www.ofrei.com/page663.html
It's too expensive imo. Not worth it.
5. OEM Dial
http://www.ofrei.com/page1123.html
again, too expensive. Not worth it.
Not sure if it fits. The worst case is to cut the legs and use dial dot stickers.
6. Bracelet Clasp
Omega Stainless Steel Planet Ocean Bracelet Clasp 1580952
Part number: OME-117ST1580952
http://www.ofrei.com/page666.html
One member installed the OEM clasp on the rep bracelet. It looks pretty nice.
7. Leather/Rubber Strap
The 4th Gen 42.5MM PO uses 20mm straps.
For the leather strap, you can check here:
http://www.ofrei.com/page760.html
Buckle and Deployment:
http://www.ofrei.com/page572.html
For rubber strap, I ve tried this one:
http://www.ofrei.com/page750.html
Omega Black Rubber Strap 20 mm X-Long
![01.jpg](http://i65.photobucket.com/albums/h228/cwai02/omega22/01.jpg)
2. Spring bar
OME-SPRING-BAR-04
4. Bezel
5. OEM Dial
6. Bracelet Clasp
![02.jpg](http://i65.photobucket.com/albums/h228/cwai02/omega22/02.jpg)
![03.jpg](http://i65.photobucket.com/albums/h228/cwai02/omega22/03.jpg)
