colt bracelet for Premier B01
devedet
better below surface
Antwerp
Hi,
does anyone know if a gen bracelet voor Breitling Colt (22-18) would fit a Premier B01 ?
Both should be 22mm
shinynewbling25
aprilia
29/1/15
1,815
3,149
Where your daughter is
Hi,
Both should be 22mm
Hi, I'm going to say no because the end links are different for most watches Breitling offers and Breitlings of different era's have different case curvatures. The good thing about the Premier is the lug holes are fairly close to the case relative to some other models so if you did find a bracelet you could most likely successfully grind down the end links until you get a good fit. Could be a lot of work though. I have a colt pro II 20mm bracelet that someone modified to fit a Galactic/Cockpit 41 case and they said it was a lot more work to get it to fit than they were expecting. Their hard work was my gain though, lol. I now have a pro II bracelet and pilot bracelet that perfectly fit my watch which dramatically changes the look. You would be the first one to have ever put a Colt (Pro I, II, or III) bracelet on a Premier most likely.
