- 7/12/11
- 6,800
- 254
- 83
Hi guys, looking to purchase some oil but got confused.
Referring to the ofrei oil chart below, it is recommended to use either the Moebius D5 or 8200 for most of the parts, am I reading it correctly?
(ETA tech sheet recommend D5 or HP-1300, but 1300 cost a bomb so im not considering..)
And after reading the description here:
http://www.esslinger.com/moebius-microgliss-watch-and-clock-oil-grease.aspx
and here
http://www.esslinger.com/20ml-moebius-8200-watch-spring-lube.aspx
im not so sure if 8200 is alright, but it is the cheaper of the two. Being a newbie i most likely gonna waste a bit of them so I wouldnt want to spend too much now.
Any expert can provide some advice?
Many thanks!
and here
Many thanks!
